MD11C cranking current and battery switch.
  • Thread starter Thread starter dur
  • Start date Start date
dur
19 May 2003
Chichester
www.gaff-rig.co.uk
The manual under starter motor says 1.5kW (2ah). Does this mean that the cranking current will be 125 amps?
The (new) 90 amp BEP vsr battery switch I found under a pile of rubbish in the garage says 275 amps continuous and 1250 cranking. I was contemplating fitting it in place of the old 1,2,both switch. We have 2 x 110 ah batteries.
No, 2 hp (1500 watts) is its mechanical output. Its consumption will be somewhat greater.
With a much larger battery than the max specified there is also potential for higher currents than intended.
However I do not think you are going to even approach 1250 amps when cranking and I doubt if you have electrical equipment that will be drawing 275 amps contiuously. If you have the original alternator the max charging current is only 35 amps IIRC
Take your pick
Acronym Definition
IIRC If I Recall/Remember Correctly
IIRC Interactive Illinois Report Card
IIRC If I Read Correctly
IIRC If I Really Cared
IIRC Image and Identity Research Collective
IIRC Impedance Imaging Research Center (Korea)
IIRC If It Really Counts
IIRC If I Recollect Correctly
IIRC International Internet Recruiting Consultants, Inc.
IIRC International Inter-Society Research Committee (on Nuclear Codes and Standards)
IIRC Internet Information Research Center
IIRC Immunity and Infection Research Centre
IIRC Interstate Insurance Receivership Compact
IIRC Information Integrity Research Centre (UK)
IIRC International Interpretation Resource Center
IIRC International Interdisciplinary Research Colloquium
IIRC Iraqi Islamic Reconciliation Conference
IIRC Inactive Item Review Code (US DoD)
IIRC Isn't It Really Cool
IIRC IVF & Infertilty Research Centre (Calcutta, India)
IIRC In Internet Relay Chat
andavagoodweekend...... /forums/images/graemlins/laugh.gif
