dur
Could anyone tell me how large the hole between the thermostat housing and front of the exhaust manifold should be? We overheated on the way to the Yarmouth Gaffers festival and in my ignorance I poked a screwdriver through where I thought the hole should be. This appeared to get us some water flow so we carried on at low revs and sail. I have now read several previous posts on the MD11C and cooling and wonder whether I should now repair the ugly hole I made or leave as it is.
I now have the manifold off and can see that one of the waterways needs more of my careful poking technique:
The other doesn't look too bad to my inexperienced eye:
I am getting water out of the drains on the side of the block so I guess they are not too bad.
The impeller is fine (apart from me shearing one of the screws on the cover - a mole grip did good service there!) and plenty of water flows into the boat when the seacock is opened.
When we got going again the temperature then fluctuated from rather cool to rather hot - up and down all the time. Coming home it sat steady in the middle how it should be /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif.
