MD11 injector replacement
Airscrew
1 Feb 2015
Hamble River and Nidri - Ionian
Further to earlier posts,
now in the process of re-assembling the heads.
I had the injectors checked and then cleaned and re-set. Helpful local Bosch shop showed me the pattern before and after.
All good now.
Q.
Is there supposed to be a sealing o-ring half-way up the body?
As given back to me, there is none, and I dont recall. There is NOT one shown in the diags on marineparts, and I think this 'groove' is the assembly line between the top and bottom halves of the injector.
But I want to check with all you good people out there.
Do I need an o-ring on the injector body?
MD11C.
Thanks.
There's no O-ring on the injector. There is an O-ring in the cylinder head, to seal the copper sleeve into which the injector fits.
