Airscrew
Hi all, a few of you may have seen my question last week about steam in the exhaust.
http://www.ybw.com/forums/showthread.php?506414-Can-you-diagnose-this-engine-symptom
The conclusion is that it is steam and a partial head problem.
So its time to take the heads off and investigate. Last time I did this was on a mini (Cooper for rallying), but that was a while ago....
I have previously removed and replaced the exhaust manifold, and admitting the need to be a masochistic contortionist again, that is straightforward.
I have studied the workshop diagrams, which are helpful.
I read the manual, which is not so helpful 'remove cylinder head!!'.
I have found a couple of useful videos on YouTube.
But I still have a few specific questions:
Release and bend (carefully) the rocker oil feed. OK.
Does this remain attached to the block, and each head is drawn over the pipe, leaving it proud, free standing, and protruding from the block?
Is there a risk of it becoming detached from its fitting lower in the block?
If the pipe splits during unbending / rebending, what is the remedy?
Presumably, you would remove and carefully store the push rods (and check for straightness on the workbench)?
Leaving the cylinder head bolts in place, would you defo replace new nuts? Does anyone know the size?
At that point, I will see an indication of wether it is only the gasket, or wether there is any sort of crack or groove.
I plan that if the block is grooved but fixable, I dont want a major project and so will leave in place and use JBWeld or similar. Any advice on the best proprietary solution for this?
If it is only the head which is grooved, I plan to take to a workshop and have it welded and machined. Any ideas on wether this is the right approach, and the anticipated cost of this?
And what is the head material? Cast iron or steel??
So, assuming it is fixable:
I already have a full head kit from KeyPart
Once on the workbench,
should I be able to see with a straight edge wether there is any warping of the head?
Can an MD11 head warp, as it is only roughly 150mm square?
Can I remove (and refit) the valve springs without a spring compressor? The (Irish) guy I saw on YouTube did it by hand (on a 2010)?
The engine had a full top-end done in c.2010, so I dont anticipate changing the value guides, but how do check the valve guide wear, with only basis workbench tools.?
I dont believe there is a compression problem, but is it worth cleaning and re-lapping these valves, or should I NOT do that because of what appears to be a critical ground angle on the valves?
Any other thoughts or comments would be appreciated.
Many Thanks.!!
Many Thanks.!!
