More than likely but if a less worn piece was available, it would be good to fit it.If you end-for-end it, you'll probably be able to use most of the existing rivet holes.
My mast has a riveted on sail track that looks similar.More than likely but if a less worn piece was available, it would be good to fit it.
Apologies for the delay in replying to your kind offer.My mast has a riveted on sail track that looks similar.
If you give me the dimensions I can check a piece I have at home.
The excessive play is due to wear of the track. There never were any plastic components involved.Should some of the slack be taken up by plastic runners?
I used to sail on a boat which had similar looking track for the spinnaker pole eye.
Do you find any benefit from a sliding gooseneck?
Can you post a drawing of the cross section with some dimensionsThe excessive play is due to wear of the track. There never were any plastic components involved.
I like the sliding gooseneck because it enables me to use a downhaul to easily tension the luff. Although there is main halyard winch I don't need to use it because I can quickly haul up the sail by hand and then tension it with the downhaul.
Unfortunately I can't because the boat is in France and I won't be going out there for a couple of months.Can you post a drawing of the cross section with some dimensions
jim
