johnjfrake
I am the new, proud owner of a Folksong 25 that I am restoring/improving hopefully making seaworthy.
The Z_spars mast is removed and laying close to the boat for work.
When I removed the support casting, aluminium sheet and teak plate I found a fairly messy sight with extra holes, damaged gelcoat etc. all of which has been repaired to a high standard. I now need to refit the aluminum mast support casting and am looking for some advice?
The original set-up had the teak directly in contact with the gelcoat with possibly a layer of mastic or paste between, I would perfer to use a thin layer of marine grade butyl rubber, are there any disadvantages to this or indeed is it worth while??
The aluminium plate rested on the teak wwith once again a layer of a white substance, now powdery, probably zinc chromate between. the two. Again would marine grade butyl rubber be an improvement and is it worth replacing the aluminium with 316 stainless steel plate??
Lastly should I use butyl between the mast support casting and the aluminium/stainless steel plate beneath it? originally there looks to have been the zinc chromate paste layer.
Thanks for you forbearance in reading above never mind any answers that come along.
regards
John
regards
John
