gavin400
My mast (deck stepped, mast head rig) has been re-stepped after re-building the mast step, and the mast is now leaning forward slightly - is this a problem?
The mast step is tapered (level at rear is higher than level at front), and the bottom of the mast is also tapered so the two surfaces are fully in contact - i.e. there is no pivot point to enable the mast to be 'plumbed up' to the vertical by means of adjusting the rigging.
Is it Ok to leave the mast as it is, or do I need to introduce some packers below the forward end of the mast base in order to make it vertical?
Many thanks.
Gavin
Many thanks.
Gavin
