simon_w
New Member
Hello, I'm new to owning a boat and am wondering if I can get some advice.
I've a keel-stepped mast and a leak from somewhere around the lower section of the 2-part mast plate assembly above the deck. I'm going to try and narrow down the source of the leak by making some dams of plumber's mait around each fitting. Is creeping crack cure any good for this sort of thing? Is it possible to re-do the seals properly without removing the mast?
Second thing is that I have a problem with halyards slapping inside the mast, which is bendy. I have tightened the rig up which I think has had some benefit but has not cured it. I've tried pulling the backstay, not much help. I know that the mast is able to move fore and aft at the position of the spreaders fairly easily as I've been up there and wiggled it to reproduce the slapping. I can't think of a simple way to damp the resonance but I do wonder if I could raise a bottle part-filled with water up a lower shroud.
Any tips on these two would be gratefully received.
Thanks. Simon.
Thanks. Simon.
