Need a bit more info
Have you had it going ?
Is the main breaker on and shore power ( if applicable ) off ?
What else have you pressed in this episode ?
It may be you did not hold down the start button long enough for the V to rise and it's gone into default mode ?
Abviously I can only guess -sorry ,if so hold down the stop for 5 secs to reset .
Assuming its all connected up and you have checked all conections for a pull and there's a decent Bat supply .
Btw -- how is it supplied --dedicated 40-60 ah or is it tee,d into either engine or Dom bank ?
Could be not just low bat ,but Zilch V ,again you have not said ,eg spent a night @ anchor all lights blazing to wake up in the morning to this ??
Need a bit more info on the events leading up to this if it's not a re-set
Sorry for the brief first post. At anchor off Paloma
Right here we go:
Mase 5.0.
Haven't used the gen since the sea trail. It was fine there.
I think that it's all pointing to a dead battery. Back on shorepower and with a trickle going in from the smart charger all the indications on the control panel are now normal until I hit start and then it flicks 'batt' and then a random code that isn't in the manual.
Now that I know where the battery isolator is for the gen I will leave it on charge overnight and see how that goes.
Good Ho .
Yup as suspected too low for even BAT , ie zilch V
You now need to understand how --- the ( new to you ) boat is organised -- which bat is suposed to be charged to power the geny up ?
How to keep that bat in tip top nick fully charged ready to go ?
How,s it got flat ?
They are all different set ups .loads of cat skinning .
Mines organised like this
I have a 60 ah simple car bat dedicated for the Geny start only .
It's got it's own charger -a small bosche € 80 jobbie from a French auto shop .The original one packed up .
This new one is an all singing n dancing -thingy -bulk -float -trickle -conditioner etc .
The Geny bat is infrequently called up on and the for 5-10 seconds .
We also have a dedicated x-over switch for the geny so if this bat dies I can temporarily rob some juice from the other two banks .
Not sure which TBO , or how that exactley works cos the other two are 24 V set ups and Geny 12 v ?
Main thing is I can start the Geny with its own Bat disconnected if needs be .I have tested this .
The other two banks are 2x180 ah - each with port dedicated engine start for both engines
Stb bank is dom / house with a x-over switch on the dash , so I could in theroey rob them -never had to .
There is the main Dolphin charger ,agian latest spec as above -fitted 2 seasons ago that from memory is overspecced 80 ah ,
Replaced an original 2003 standard 40 ah --which did not pack up ,just decayed ended up down to 5 ah before skipping it !
I had the whole boat gone through by a boat sparky -Sunseeker use and some ammendments made .
What you need to try to prevent is this ----
After a deep Dom discharge @ anchor and starter bat probs occurring ( in a sods law way -together ) should that ever happen in some god forsaken place then the last chance saloon is the Geny --then get that to run the main charger 80 ah into 160 ah ---- well thats theory .
Basically your Geny bat needs to be the last of the sets to die .
