lydiamight
Mariner 4 O/B water \"tell tale\"
I have a Mariner 4 outboard engine--a twostroke dating, I would guess from around 2000/2002. It came with my boat when I purchased it so unfortunately I don't have a manual for it.
It's not been used for a couple of years,other then a couple of test runs in a wheelie bin full of fresh water.
Got the engine out tonight with the intention of using it over the weekend--question is--should the stream of water that comes from underneath the engine cowling be continuous or not. When running it up to full operating temperature the water stream seems to alternate between a stream of quite hot water (hot enouggh to wash your hands in) which then becomes a dribble and then stops all together--just a jet of steam comes out. It will then revert to a jet of hot water and so the cycle repeats itself. Should it be like this because the thermostat is cycling or is there something wrong with it?
Tried poking out the various water inlets and outlets and everything seems clear.
