ProDave
Launch day today, and like last time, the motor let me down. A 2003 Mariner 4 2 stroke outboard.
2 days ago, I ran the motor at home in a tank of water. It started first time, I ran it for a while to warm it up, and ran it in gear (only at low revs otherwise it empties the tank!) The motor had been stored upright in the garage over winter.
So I launch the boat, and the motor won't start. Had to walk the boat from the slipway to the harbour again.
2 hours later when everything was set up, the motor started and seemed to run okay.
As I say, we had the same problem last year. That time I bought the motor home and found gunk in the fuel filter bowl which I blamed, but now I'm thinking that was a red herring.
The common theme is both times it has failed to start it has been on it's side for about an hour. I'm beginning to think this motor does not like that.
Both times, it would start, but barely idle, and die as soon as you put it in gear. Sounding like fuel starvation?
Anyone else experienced this problem, and is there a solution such as perhaps turn off fuel and run the carburetter dry before transporting for instance?
Otherwise I'm tempted to fit a wooden block to the trailers winch post to transport the motor upright.
