exfinnsailor
Mariner 3.5 Won\'t Idle
Our year old Mariner is running fine but will not idle .. Tonight i have removed the carb and cleaned up the oil that was in the case .. I presume the oil has come from the sump via the breather into the top of the carb .. I have also found two rubber pipes that exit underneath the engine and connect to the top of the carb .. One had oil in it and was in the bottom of the engine rather than fed to the outside .. QUESTION is it the oil that caused the problem .. ? .. What are the pipes for ..
