sarabande
2003 year, with <12 hours running. Has been properly run in, and serviced very carefully.
Petrol mix is exact, and petrol is about 1 month old (premium type)
Symptoms. ( Outboard mounted in wheelie bin; water covers cavitation plate.)
From cold, air tap and fuel tap open, fuel flows to carb bowl in what I consider a decent stream. I have blown back along the fuel pipe into the tank: it's clear. Bowl has been drained and cleaned (just a little waxy stuff at the bottom). Float looks fine, no leaks.
Compression is fine.
Starting prob
Choke to CLOSED, throttle to START mark.
I take up the ratchet and compression on the cord, and heave smartly.
The engine catches for about 2 seconds and a reasonable amount of smoke from the exhaust. Engine dies. An immediate second pull produces no reaction, but leave it for a minute, and the same very short run takes place. Fiddling with choke and throttle does not change the result.
Plug looks OK.
I am not certain of the adjustment screw, but last time I had the engine running, everything was fine and ran nearly full throttle OK.
My manual does not refer to the adjustment of the screw in the carb, but the problem looks to me to be in the fuel flow,
I face East when trying to start the motor, and talk encouragingly about the weather and how we are going to enjoy going on the water.... Any other suggestions please ?
Starting prob
Plug looks OK.
