davidbyng
New Member
Hello, new member here, I have a 2017 Mariner 15hp 4 stroke outboard, try as I might it will not fire, I have done the following:
Ensure no water in fuel.
Ensure no blockages in fuel line.
Fuel tank vent open.
Primer bulb is hard.
Remove fuel pump and check diaphram.
Ensure fuel filter not blocked.
Removed, stripped down and cleaned carb, float and needle all free and working correctly.
Empty carb drain plug, plenty of fuel.
Ensure starter motor and solonoid are working.
Ensure battery is good.
Replace ground and live leads.
Ensure kill switch is functional.
Ensure water pump is working.
Tested spark plugs with multimeter and reading 4800 ohms.
Tested ignition system with inline spark tester and it illuminates when cranking on both HT leads.
I can't think of anything else to try, any advise is much appreciated.
Many thanks
David
Many thanks
David
