l'escargot
Blimey!
Serious business the capacity of toilet cisterns you know! Not to be made light of...
Blimey!
Claiming to have never screwed up seems like setting oneself up for a fall...
Hmm so is toilet/ shower 'abuse' restricted to the male domain or do anti-social behaviors extend to the female facilities also?
While at university, I learned that the cleaners got what they called "dirty money" - £5 in cash if required to remove a turd from a shower.
I'll admit I was shocked that this ever happened at all, let alone was common enough to have a standard procedure.
I still can't fathom how the situation would arise. Yes, a selfish person having shat in the shower probably would leave it for the cleaners, but why would they have done it in the first place?
They should throw the bath turd out.
I'm probably expecting the perpetrators to be too decent, but I wonder if embarassment about cleaning up is the key, and little wet room compartments containing both loo and ' over bath type ' shower - so the shower head could be used as a , erm, cleaner - might be the answer ?
Signs like ' please leave these facilities as you would wish to find them ' clearly have little effect, and let's not forget our country and ourselves are judged by overseas visitors on things like loos; an ex girlfriend refuses to visit St Malo or possibly all of France again after a harrowing incident involving a public loo !
It amazes me how picky some people are
far too picky to be sailors IMO
Dylan,
Expecting people to clean up after themselves is not picky, it is simply good manners to leave a facility as you would like to find it. Whether that be in a sailing environment or any other environment is irrelevant. If people like to find a loo plastered in the result of the last persons visit then I am afraid I cannot help the poor devils.
Rob
it was the post about a shower and bog in the same room and the fear of going in there 15 minutes after another person has used it
D
I must say I feel the opposite, I can find a berth and tie up ta very much, but after stumping up my extortionate fee I don't expect to have to clean bogs !
And the smell?it was the post about a shower and bog in the same room and the fear of going in there 15 minutes after another person has used it
clean up before and after you have used it
problem solved
as I said earlier... you are either part of the problem or part of the solution
D
The shower in "a certain place" in the Outer Hebrides, is actually in the Disabled toilet, and is effectively a Wet Room. It costs 50p, and gives more than enough time for two people to have consecutive showers. Can't be bad.
So you are the one that leaves them filthy after you have used them
Kind of goes with the perception of you that one gets reading your posts on this forum
And the smell?
Besides waiting 15 minutes means that someone else will go in before you & repeat the process
