Bru
If the owners of toilets fitted plugs there would be a lot less paper stuffed into plug 'oles.
And a lot more water on the floor
If only someone could invent some sort of secondary drain for sinks which would prevent them from overflowing, eh?
That would be a Niagra Falls effect - modern cisterns in the UK are generally 6 litres/4 litres.
Fitted a few myself. You must have fitted yours a while back, if you fit any new ones they will be 6 litre/4 litre - 6 litres is the legal maximum under current regulations, since 2001 in fact.
See page 9 here:http://www.southernwater.co.uk/pdf/property-and-developers/water-regulations/WaterSupplyRegs.pdf
I think they should be prepared to work overtime during summer weekends for no extra money at all
OK I must be out of date, though fitted a LOT of syphon units well after 2001 so that needs checking...
Yep, checked it for you - Water Supply (Water Fittings) Regulations 1999 Amended 2001. Looks like you did some dodgy installations that didn't comply with the regs if they were new installations....
No pleasing some people.snail,
despite your ill wishes I have never done anything dodgy or illegal in my life; I am quite sure I will be proven right.
You are a pretty nasty piece of work aren't you ?!
Ooh dear - I think you are protesting too much now. Really, trying to bring religion into a discussion about plumbing, that is a bit silly - and a bit strange too. Well above the regulations? It looks like you didn't even know what the regulations were. Just more outdated information from you as usual...I can sleep at night knowing I have gone well above the regulations; have you any similar feeling about anything you do ?
As I suspected, a nasty vindictive little berk with nothing bettter to do than preach idiotic religion ( the source of many a war costing millions of lives )...leading to a lot of people - hundreds of thousands -getting killed...even if I screwed up - which I never have - I might have to try pretty hard to reach those figures !
