Dougal
Is there an inexpensive way of testing for this????
Ta!
Ta!
Just get one of those 3 pin testers with 3x3 light combinations from B&Q etc, and plug it into a blue three pin to marina male socket. About £30/40 fo,r the two, tops, and you can use the 3 pin/marina unit for drills sanders p/washers as wellIs there an inexpensive way of testing for this????
Ta!
Ta!
one of the plug in socket testers such as http://www.diy.com/departments/bq-230v-socket-tester/178677_BQ.prd that you can plug into a socket on your boat
or neon permanently wired between earth and neutral
That item is marked "This unit will not detect earth neutral reverse" !!
Errrr.... so whats the difference between 'earth neutral reverse' and reverse polarity?
Why not just stick your digimeter probes on AC volts and a suitable scale into the socket? Neutral to earth should be nought, live to both the other 2 should be lots. You'll probably find a bit of a voltage drop from 220v - worse the further away from terra firma.
Apologies for the drift, but I'm curious. How would you go about detecting reversed earth & neutral? As I understand it, they both go to earth not far up the line in the UK. Also, would it matter to me on my boat?
It is, or at least was, a different story in France. I used to fix vending machines and was in a factory working on one of our machines and measured 100+v between earth & neutral. I went to the maintenance guys to tell them about the "fault" I'd discovered, only to be told that it was nothing unusual.
