pcatterall
Following my post about bilge alarms and following my flooding problem I had to use the manual pump.
I do test this from time to time ( just in case) I realise now that I should have tested it 'in anger'
I operate the pump by the wheel house door so I can in theory just shove one end down into the bilges and the other end out of the door. I found that the hose was too long and very stiff and that it was hard work holding the pump down with one hand while pumping with the other.
Lesson learned is that I need to select a place where I can rapidly mount the pump properly and get the hoses to the optimum lengths so that I can pump efficiently ( While firing the flares with the other hand!!)
Any other tips
Any other tips
