longjohnsadler
My relatively new to me boat has one of these.
After recent relaunch, second trip (not first) saw appreciable amount of water ingress at high engine revs, falling to nothing at low revs/engine off. Local mechanic had a look and adjusted rotating seal tighter against stationary seal by means of jubilee clip. Problem seemed to be solved. Later I found tag labelled 'break in emergency only' lying (broken) below the seal.
Just found website that says these seals should need no maintenance, and that under no circumstances should shaft be rotated if emergency clip (protected by emrgency tag) is tight.
Am assuming emergency tag has fallen off without emergency clip being engaged ( I hope)- but not sure why it would let in so much water or need adjusting?
Also I'm assuming it's a lift out to fit new seal..
