tcm
This is a bit PBOish cept that it concerns monster diesel engines, hence this is the best place i think.
Anyway, been down to the boat in soton after 3 weeks calming down at the prospect of it getting fixed costing 12 grand, and so-called 5-year Gold warranty only covering "major" engine parts like er the casing and crank against "manufacturing defects", hence not really very gold in my book. I'd call it "limited" warranty , not "Gold". Gold warranties should furnish me with a spare boat whilst this was being fixed, and another one if i smashed/sank that one as well, which one of our company car drivers did recently er, but that's another story. Suffice to say that the trip to the uk and back would've been cheaper if i had a bought a reasonable ferrari and chucked in a skip on my return ...but anyway.
The starboard engine started getting a bit smoky. Then, in august at cowes, it got really very smoky indeed.
So, i drove it to saxon wharf near where the MAN peeps are and toldim it's a bit bustified, and they found that the camshaft drive to the fuel pmp is broken. Hm.
Now i hope i will get pix, but anyway, the problem is that the monster straightcut gearwheel that drives the fuel pump has lost four teeth. So the pic wd be a big shiny camshaft bout a metre long on the end of which is the camshaft drive gearwheel from the crank (bout 9 inches diameter) which is fine, and inside that also on the camshaft end is the fuel pump gearwheel (6 inches dia) with four teeth missing. Like someone has dropped a spanner in there while it's running, cept i didn't. It's all one big assembly pressed together, so whole new camshaft assy needed.
The nice egrs found the four teeth in the sump, got a new camshaft, put it all together and ran it up on the bench today, but my question is...what the hell happened inside a fuel pump (or camshaft chamber) to rip a tooth out of a massive gear wheel eh? I mean, the gear wheel is about 6 inches in diameter, 2 cm thick. It drives a pump which sucks fuel. The shaft isn't bent, and i spose once one tooth went, it probly ripped the others. But why did the first tooth go?
The engine did have a fuel contamination problem a year ago (DOWN depsol!) but all that happened was it slowed to a stop - and the blockage was way upstream, not in the pump.
Having had and abused countles motorbikes and cars, lots of which have busted/seixzed - none busted the gears in the gearbox like this, so i think it cd be a bit worrying. Is there summink really very hard to drive in a fuel pump? Could this happen again?
Yet another example of poxy german engineering hiding behind the coat tails of Benz, i wonder? Or er is MAN part of the same group? Or is that MTU? dunno.
MAN have seen the damage and agreed to pay for the parts. Which, okay, is £2000 but a fraction of the cost of the work, and sortof shows that yerknow, they're a bit guilty. I mean, either it's their fault or not innit? I spose this is what my three weeks of calming down was about - it had 2 years on that part, not five. Grr gmmf...it's okay, this will pass. Anyway, the main thing is that i don't want it to happen again.
Also ...how long cd the engine run with a busted gear drive to the fuel pump? Surely - not very long? Or could this have happened/started ages ago?
Coments please.
Coments please.
