Making sense of battery installation on new boat...
weaver_fish
10 Aug 2005
I have very limited knowledge of boat electrics and can't make sense of the battery switch set up on my new (to me) boat.
Has a domestic and engine battery with two simple switches. The photo shows the back of these switches. What is the purpose of the small square Bosch thing?
Here we go...
What's it all about :)
DaveS
25 Aug 2004
West Coast of Scotland
It looks like a relay. To make sense of what it's for, however, you really need to trace out the wires, see what's connected to what, and (preferrably) draw a diagram. It might, for example, be wired to parallel the batteries when the engine's running, by taking a feed from the oil pressure or something - or it could be something completely different. Without knowing the actual schematic, however, it is pure speculation.
jwilson
22 Jul 2006
Doesn't look like a diode. Could be a voltage sensitive relay, that only connects the two batteries in parallel when the voltage on the engine battery rises to around 13 volts or so - thus charging the critical (engine) battery first before connecting to and topping up the domestic battery.
Oldhand
21 Feb 2002
UK, S.Coast
I believe it is a plain relay. At a guess from the pictures it paralells the 2 batteries, probably when an output from the alternator is present, but depends on where the black wires are connected.
johna
12 Aug 2001
Poole
As others have said it appears to be a split charge relay. The pics do not show the complete route of the green wires but I assume they just link the two switches together. If so they look of a lower amp carrying capacity than the starter battery switch cables and while the intention is that they only carry a charge from the alternator if the relay contacts became welded together then those green cables could be carrying the whole or part of the engine starting current. I would suggest that a circuit breaker rated to cope with the max alternator output is inserted in the green circuit if there is not already one there to protect against relay failure.
William_H
28 Jul 2003
West Australia
i really object to the term "charge splitting relay.' because it is misleading. "Charge splitting diodes might be OK but not a relay.
The relay is used to apply charge to an other wise inherently isolated battery system. So why not "charging relay" (Not that I could ever hope to redirect the progress of the English language with the passage of time)
Anyway it does look like a plain relay as fitted to cars for headlights or horn. If the domestic battery had a circuit breaker thne if the charge was directed on the side of the CB away from the battery that would protect the wiring from start current if the relay should weld its contacts.
The relay can as already stated be driven by an oil pressure switch or even a rectifier off the aux terminal of the alternator. Which only gives output when the alt. is charging.
So using a multimeter check the domestic battery voltage before and after start up of the engine. It should be around 12.5 volts or so going up to 13.5 or more with engine running.
Now do the same test with one of the wires of the relay disconnected. If the domestic battery does not rise in voltage ie no charge then the relay is indeed a charging relay. (A good system to my mind)
If that is the case it will be desirable to track down the wires that go to the coil of the relay. One may go to -ve common wire. The other may go to the engine panel or to the alternator. if you can find a aux terminal on the back of the alternator you could remove the wire. If the engine battery gets charge but the domestic doesn't then that is the clue. Like wise if you find a likely looking wire that goes to the engine panel and or oil pressure switch. good luck olewill
whipper_snapper
9 Aug 2006
Kenya
Indeed. The only thing that's missing IMHO is a 3rd 'paralleling' switch to allow you to use the domestic batteries to start the engine in an emergency.
halcyon
20 Apr 2002
Cornwall
Well since 1970's I've always known them as
split charge relays.
As in allowing a charge source to charge two or more battery banks.
I think charge spliting relays is a typo error, that someone has copied.
Brian
johna
12 Aug 2001
Poole
William
From what I can see you are the only person to use the phrase "charge splitting relay". Most have used the expression "split charge relay"
