Sniper
I am in the process of replacing bolts which go through steel galvanised floors, keelson and deadwood. These bolts were originally about a foot long but have now wasted away and in the process have degraded the surrounding wood. I have removed the remnants of the bolts but am now left with holes to fill prior to fitting new bolts.
My plan is to over-bore the holes sufficiently to reach sound wood and then epoxy in dowelling of the correct diameter to fill the holes snugly. I will then re-bore the holes for the new bolts, which are likely to be around 3/8 - 1/2 diameter. Does this sound like a sensible way to proceed or is there a better way?
Boat is 28' carvel built Twister.
