Norman_E
I need to make a new instrument pod to take my new instruments as the old one is cracked and the cut-outs in it are in the wrong places. I have thought of making it from PVC sheet, but that is only available in grey, and will not look good. My preferred method is to make it from WBP plywood glued with PU and, with all edges and corners routed to a smooth radius. As I want a durable white finish should I coat it with flowcoat, or paint it. If the latter what should I use? My only fear with flowcoat is that expansion & contraction of the ply may crack it. Is that likely? The plywood hull stringers in the bat are coated with flowcoat, with no signs of failure, but they are not subjected to big extremes of temperature.
