whiteoaks7
Winter project number 3 - fit davits. Ok, the only problem seems to be that the transom is not horizontal so I need to build up the area onto which the davit socket will sit. I could use wood but (a) it will rot in the end and (b) the shape is awful - sloping from 8mm and 10mm to nothing in north-south and east-west directions.
So I think GRP would be best but I know nothing of GRP, so here are my questions:
1/ Can I simply use something like chopped glass filler from halfords? This seems to have the advantage that it will be easy to knead into the right circular, complex wedge shape. I would hope to be able to smear the stuff over the base of the fitting then wiggle it into the right orientation. Is this naive?
2/ Or do I need to build up the area with successive layers of mat and resin. If so, what mat do I want and are all resins equal? (I assume ester resin, not epoxy?)
3/ Whichever way I go I want to finish the rim with gel coat filler, of which I have plenty but it is too runny. Is there something I can add to the filler to bulk it (talc and marble flour ring vague bells) and where can I get some?
