Thepipdoc
I'm currently having my saloon upholstery refitted but the upholsterer contacted me today to say that he has got all of the panels off the boat that are being recovered apart from the one that sits alongside the helm seat. (See the picture).
It's not screwed or bolted from the underside, it's apparently glued and its solid!
So solid he's afraid he might break something if he uses any more force than he has already.
He says there's no way he can do a proper job unless he has the panel removed.
Now, given that it's not moveable I'm considering making a replica out of fibreglass and fixing the replacement on top of the existing one. The upholsterer can recover it as long as it's a rigid.
I would of course remove the fabric and the foam padding prior to starting to make the fibre glass replacement but given that I've never worked with fibre glass before is there anything I should be aware of before starting?
One thing I'm unsure of is how do I "stick" fibreglass to the existing panel and yet be able to remove it when it's hardened?
(The picture I've attached is a one I picked off Google and not a picture of my own boat but I'm hoping you can see that the panel needs that needs to be recovered. I'm nowhere near my own boat otherwise I would have taken a more detailed picture)
