claymore
Claymore has a centre cockpit/semi-enclosed wheelhouse. The mainsheet is a triangular setup with no traveller so:-
It leaves the cockpit along the port side of the aft cabin top. goes through a block, up to the boom, down to the single starboard side block , up to the boom down and is fixed at the port side double block.
I cannot sheet in to windward when motorsailing, can seldom gybe without getting some form of knotted cluster and sometimes even manage to jam the sheet down the cheek of one of the blocks, despite the sheet being the correct size for the blocks.
Further aft there is a wooden bar which I could use to screw/bolt a track onto.
Question - I will always need to sheet in on the port side of the cockpit because the hatch for the aft cabin is in the centre. Can I use a track and then lead the sheet through the existing port hand block or does this sound a bit of a nonsense?
<hr width=100% size=1>regards
Claymore
/forums/images/icons/smile.gif
Claymore
