silverdawn
Hi I have a wooden boat with a central traveller mounted on an arched metal support across the rear of the cockpit, I think they are known as a (horse) the problem being that you have no control other than pulling down on the mainsheet very hard to try and position the boom , in very windy weather when tacking the boom crashes across, the horse is solid 16mm dia s/steel with no way of putting any form of intermediate stops.
I have heard of a set up where you can rig a traveller system up with port and starboard sheets through blocks which give you full control in any position and also has the advantage of being a preventer when sailing downwind.
Any advise /diagram/other methods would be welcom.
