vyv_cox
The OP`s Nic 30, will be well balanced & sea kindly so less likely to broach violently, a real sea boat
Good description of a Sadler 34. I have never broached it, violently or otherwise.
Me neither & rarely under canvasedGood description of a Sadler 34. I have never broached it, violently or otherwise.
Mine runs across the bridgedeck, so really not in the way at all as people need to step over to get to the companionway. For me that is its ideal position, easy to reach and adjust. I alter mine frequently. Only problem is when berthed, which is solved by having the mainsheet on a snap shackle to be moved outside the cockpit to one of the stanchions.
I also have the lift-up pegs to control car position. The magazines constantly tell us to replace these with haulers and cleats, but they would occupy the most comfortable seats on the boat. Provided the pegs are moved before tacking rather than after there is no problem with them.
I know about control of twist by use of the track, I was just weighing up it's usefulness against it's inconvenient location. The proposed u bolt would be hard against a hefty triangular section footbrace which runs along the cockpit floor, so toes should be safe. Boat is a Nicolson 30
A boom intended for mid-boom sheeting needs to be a lot stronger than one where the load from the clew goes (pretty much) straight down into the sheet.Of course, any mainsheet mid-cockpit is inconvenient and can be dangerous. My boat has the horse in front of the mainhatch and is in continuous use (Sailing or motor-sailing
Replacing the current track with a fixed U-bolt is, IMHO, a regressive step as you'll still have a nuisance under way and you'll lose a important part of sail control.
Why not replace the current system with one ahead of the forehatch? and do the job properly?
How does one attach a mainsheet in front of the forehatch?
A boom intended for mid-boom sheeting needs to be a lot stronger than one where the load from the clew goes (pretty much) straight down into the sheet..
Where are you going to get another toe from?One day will get round to replacing it.
I understood that the disadvantage of a clew fitting, such as most of the Westerlys, is that the force of the wind on the sail will stress the boom by pulling it upwards, and that somewhere further forward was easier on the structure. Not applicable with a loose foot, of course.
I don't see where the OP says he has in mast reefing?A main sheet track is great aid to performance on a boat which already has an efficient mainsail, the track is a reasonable width across the cockpit, and has adjustment ropes led so they can be easily adjusted / played from the windward rail.
The most common modes are (a) track to windward for better pointing in light winds and (b) dumping the track to leeward and then rapidly pulling back on again in gusty weather.
However, I doubt most main sheet tracks on cruising boats are set up effectively nor used effectively. And certainly must be near pointless on a furly main boat.
So for the OP, if the track is not used in the modes (a) or (b) today then removing would not cause any loss of performance.
If interested in racing, fitting a wider cockpit track with rope adjustment would be worth considering.
I think if tracks did not make a significant difference AWB builders would be pretty quick to save £££ and have a U bolt instead?
I use the traveller a lot on the boat. We're hardly a close winded boat so it helps with that but when it's time to motorsail the traveller is superb, helps you keep the main up and drawing at extremely close angles to the wind.
Yes, but is actually pushing the boat forward?
