mainsail halyard
EASLOOP
17 Dec 2001
The Medway, Kent, UK
My East Anglian has a keel stepped mast with about 34' showing above the deckhead. She is 27' 10" LOA, 8' beam. Jimmy Green says I need very low stretch braid on braid halyard of 10mm diameter. That seems a little small to me, 12mm looks more like it. Does anyone have any advice they can send on which would be more suitable?
tomainsley
29 Mar 2008
on our hunter 37.5 i recently went down to a 10mm kingbraid with 2800kg breaking strain after the same deliberations. I went to 10mm to reduce friction through the blocks and make hoisting quicker/easier, 10mm and 12mm seemed as comfortable as the other. (10mm is cheaper too, although was a devil to splice).
Tranona
10 Nov 2007
12mm is OTT. No benefit of extra size on a halyard (unlike sheet where more handling required). Also unlikely sheave is big enough to take 12mm.
EASLOOP
17 Dec 2001
Looks like I had better 'fondle' some samples. My halyard runs outside of the mast (I have replaced wood with an old ally one the lining of which could mistreat the rope were it inside the profile.)
Thanks again. I am favouring the 12 mm. As I say, best do some touching.
Tranona
10 Nov 2007
Even more reason to stick to 10mm. Perfectly adequate strengthwise, lower cost, less windage, less weight aloft.
KenMcCulloch
22 Apr 2007
Edinburgh, Scotland
My mast is the same height as yours, give or take a foot or two and I use 10mmfor my halyards which is completely adequate. If it's going round a winch you will get more turns on with a 10mm line than 12mm which may be much more important than any slight gripability (new word?) difference
simonfraser
13 Mar 2004
you checked out the breaking strain of 12mm dyneema ??
i use 6mm on my asymetric and that will neva break. cheaper too.
EASLOOP
17 Dec 2001
Thanks for the generous response to my question. I am going to give it some more serious thought. The lower price of 10mm is not to be sniffed at. But more importantly is the carrying capacity.
William_H
28 Jul 2003
West Australia
You need to remember that with a main halyard all the load of a proably 4 to 1 purchase main sheet plus a vang is going to be pulling on the halyard when close hauled. This is going to cause the rope to stretch.
I used 6mm specta halyard on my jib (a much smaller boat) and was dismayed to find that after a little sailing I needed to retension the halyard because of stretch.
So I would suggest yes 10mm rope but get the expensive spectra dyneema type rope or stick with wire/rope. olewill
