DaveNTL
having just replaced two expensive gel house batteries on the 'new' boat (2001 boat but its new to me, this is the 3rd set of batteries it's had) i'm a bit baffled as to the design phylosophy it has, and i throw open to you (the oracle) for comments about it
what doesnt seem logical to me first off is that when plugged into shore power it goes through the charger / batteries / inverter to run the socket outlets of which there are 10 in the boat - typically i run a microwave, toaster, tv, and electric fan heaters.
I cant run all these at once, not that i want to of course, but at the moment i am limited to, say, one heater and the microwave.
if i put anything else on the battery charger breaker trips.
the refrigeration is 12volt, so i understand why that would always coming off the batteries
it this 'normal' ? wouldn't either a manual or perhaps even an automatic change-over switch of some sort be more sensible to run the mains when on shore power?
i think the design 'problem' comes from the generator / inverter size - i.e. the thinking behind it is, when not hooked up to shore power, if the generator can only provide 4kw and the charger / inverter are matched then that is how much power there is and you have to live with it
on a final note - i then went on to thinking - even though gel cells are supposed to be good at taking a deep discharge and recharging many times, maybe this has contributed to having them replaced so many times
or maybe the charger is dodgy
any input ( AC or DC! hahaha! ) will be much appreciated - Dave
