nicclark
Hi,
I really need some help with my magneto and I am hoping there may be some people who know about them, so here goes...
I have a classic Fairey Faun, just finished restoring her. She was factory fitted with a Morris Vedette MKII engine which has a lucas rf4 magneto.
The engine needed some attention, which it has now received, but I had to take the magneto off. I also needed a new coil for it which I installed, cleaned the mag up and replaced any bits it needed.
With the mag on the engine, there is a spark at all 4 plugs unless I move the advance and retard lever to fully advanced, when the spark stops. That's the first issue. The second is getting the ignition timing right between it and the engine - I have tried engine at power stroke TDC and the magneto just before firing #1 and got very little - some white smoke and a few backfires.
There is no timing documentation with the manual for the engine - and timing is not my best subject! Do I need to move the engine on a little from TDC so it is further into the stroke? Is it best to experiment?
Regards the spark cutting out at full advance, have I set up the internal timing a little wrong?
Everything else is OK and the engine was running last year. Carb is working, valves all ok.
I would really appreciate any advice or help - I just need to get her started to get out on the river!
Thanks!
Thanks!
