2 uninflated life rafts?![]()
Scary how fast it went down ....
20 metres of painter not pulled out yet?
I hope I never need to see the inside of my life-raft
Looks like the painters weren't pulled out
BUT
should they be attached to the boat so when rafts float free they automatically "pull"
OR
is that plain dangerous, as they'll go down with the boat.
Do you have a hydrostatic release? If so, you should have followed the instructions to attach the painter via the supplied weak link (the red and black plastic parts pull apart at a set load). That should leave the raft attached as it floats up, then the pull of the sinking boat fires the inflation system, then the weak link parts to set it free.
The video ended as soon as the sinking boat went below the surface - not long enough to have pulled out all the painter. Hopefully if the video continued, we'd have seen the rafts inflate.
I wonder how fast a yacht would go down?
there was a yacht going up the Irish sea to west highland week a few years back and its rudder broke off at the hull bearing. The rudder shaft pushed up into the boat allowing water into the hull
About three minutes according to the report
Fortunately mayday was received and crew were picked up by others on the same passage.
yep, brand new & it wasn't a bavaria![]()
