D
Deleted member 36384
My boat is fitted with an old style Lucas ignition switch, turn to power up, turn against spring to heat, turn further against spring to power starter solenoid. I had to fiddle with the switch after 2 1/2 years lay up and noticed that a brown with yellow strip wire was not connected. There are two spare male spades on the switch, a large one and a smaller one that fits the brown / yellow spade connector. The male spade on the switch is a double spade and also has a large diameter white wire connected to it. The engine runs fine without the brown / yellow wire connected but I am wondering what it is for. There is an old push to start spring button on the throttle console which has been decommission many years ago and is not used, I wonder if that is what it was for? Any ideas?
