Lucas alternator replacement
Raymondh
14 May 2004
We have one of last built 1974 13 ton Hillyards fitted with a Tempest 3 1/2 litre diesel engine and have just noticed a significant fracture in one of the securing flanges of the alternator. Clearly this needs replacing urgently. Since this is the original Lucas alternator, operating through a split diode charging system with a positive earth circuit, finding a suitable replacement presents a problem. Does anyone know of a company in the Solent area who may be able to supply a suitable alternative alternator.
halcyon
20 Apr 2002
Cornwall
Look up your local LSUK depot.
Which model do you have?
Thought alternators were standardised on neg earth ? cannot remember a pos earth one, but then it's a long time ago now.
Brian
nordic_ranger
6 Oct 2002
GREENOCK SCOTLAND
If the alternator is running OK electricaly why not take it to your local Metalworker and have the fracture welded. Save on the cost of a new alternator. Just a thought.
Jim.
ongolo
5 Aug 2003
Not sure I understand why it should be gas welded?
Surely TIG welding is the way to go!
Also I am not sure where the crack is, is it one of the mounting points? (not critical) or is it where a bearing is seated? Either way it can be completely repaired with some care. If the area of the bearing seat is affected, also no problem, put it in a lathe, have thin bushing made and use a bigger or smaller bearing as required.
I am not sure about Lucas, but Bosch uses a plasic bush to cushion the noise of the running bearing. It would do no harm to have a teflon bushing turened (or Veconite, or Vesocline) to compensate for changed bearing housing size.
Bosch proves that this is viable technology.
Fixe it dont ditch it.
regards ongolo
<hr width=100% size=1>1000 dream about it, 100 talk about it, 10 start and 1 completes it
halcyon
20 Apr 2002
Cornwall
If it's Lucas, it's probable that the end casting of one from the scrap bin will fit, or scrap yard, far better than trying to repair it and chaeper.
Brian
Gunfleet
1 Jan 2002
Orwell
Of course, if you've taken the trouble to take it apart first TIG would be right. I was just warning - when you do electric welding on a car you have to disconnect the alternator for fear you'll fry it (which a friend of mine actually did once in front of me while I was a youngster). If you're welding a lug on the alternator you can't disconnect it so best choose a method with no electrical input. But I think better yet is halcyon's idea - pick up the part from a scrap bin. One last idea is to give it to an auto electrician. Our local bloke charged £60 to revive my cruddy, rusted and stuck Yanmar (actually Nippon Denso) starter motor from scrap to 'as new' condition. God knows what Yanmar would have wanted for a new one.
Gunfleet
1 Jan 2002
Orwell
iangrant
By the Sea
Talk to Superstart in Southbourne - 01243 379865 - they have just about all marine (and auto) alternators in stock.
For refurbs drive to Cockleburry farm past the pub on the left at Chidham
iangrant
By the Sea
milltech
31 May 2001
Worcester
www.iTalkFM.com
I was given this information as a company that this year suppled a Lucas CAV alternator for a 1955 vintage boat, mind you the price wasn't cheap.
LS UK Southampton
Atlantic works
Oakley Road
Southampton
023 80777111
<hr width=100% size=1>John
http://www.on-line-marine.com
TonyBrooks
10 Nov 2003
Berkshire UK
Lucas 10 & 11 ACs (the ones with the seperate regulator (4TR) and warning lamp control) did come in pos. and neg. earth and I think both used the same end brackets, the worst you might have to do is to open out a hole.
Also I am fairly sure the ACRs (the ones with a big plastic cover at the brush end) were available in pos earth for a very short while. In marine use I would expect it to be an 11AC.
Tony Brooks
