alt
Decided to change the water impeller on my KAD32 today as the boat will be going back in the water in less than 4 weeks. I know you should leave this until the boat is going in the water but I just wanted to have it over and done with
BTW I removed the whole assembly to change the impeller - It was only a 2 nut job - Thanks YBW for that tip, made life so much easier!
Now I used the lube that came with the impeller but when it was in I sprayed in some fairy washing up liquid and gave it a few turns. Since I won't be using it for 2-3 weeks, is it OK to just leave teh Fairy in there? I know to expect a foamy water outlet for a minute, but other than that is it OK? If needs be I Can drop the boat in the water tomorrow and give it a run
