Lowrance mount - Plasticlip for 35mm Tube???
Richard10002
17 Mar 2006
Manchester
Hi,
I want to fit my new Lowrance 3600i to the 35mm tube on the steering pedestal and, when the chap in the boatyard pulled out the Plastimo Plasticlip it looked like just the job.. in fact Plastimo do an adaptation for a plotter which would probably work..
http://www.plastimo.com/catalogue/search...p;s_choice=name
Except that it only fits a max 25.5mm diameter tube, whereas mine is 35mm
Any ideas for something that will do a similar job, on the bigger diameter.
many Thanks
Richard
Re: Lowrance mount - Plasticlip for 35mm Tube??? Or other ??
Yep ..... something like this ?
Available in various sizes at your local Plumbers merchants. Designed for holding domestic pipes in place against the wall with a small gap. Takes a standard bolt into the metal boss.
Seems I was looking at a similar question on the group site ???? The above didn't come to mind then ...
