Lowrance GPS & XM DSC Not talking!
wetandwindy
22 Jan 2005
Cardiff
I've trawled the archives, but can't see a solution to this, so would appreciate any guidance. I've got a Lowrance M52i s/GPS linked up to an XM DSC VHF. The DSC resolutely refuses to acknowledge the presence of the GPS. All cables are sound and connections OK. I've tried all the permutations of the NMEA speed that I can see and also tried every other setting possible. What am I missing here guys? /forums/images/graemlins/confused.gif
Just a thought...
The data cable which comes with the M52i has a diode and resistor built in to it. These aren't needed for some radios. Is it possible that the XM is one such radio? See manual supplement for details.
Danny, cheers, I had to play around with the menu quite a bit originally, but yes it is. /forums/images/graemlins/frown.gif
PVB, I looked at that and have connected the cables prior to the resistor/diode, to no avail! I will now try completely disconnecting the diodes and see what that does. I assume that it won't cause any damage.... ? /forums/images/graemlins/crazy.gif
there can be some confusion about earthing - as happens a lot with NMEA devices from posts here!
gererally connecting GPS with VHF........
any shield, earths or NMEA -ve 's should be directly connected between the 2 devices rather than relying on them connecting somewhere on the boat through both being connected to earth.
other than that it's NMEA +ves together, which you have done.
GPS as NMEA out in software for the com port if it has to be configured
NMEA out message set to one acceptable to VHF - probably 2.0 for these units
VHF set to accept same message
baud rates same 4800/9600
and for some MMSI number programmed into VHF or it won't show position
also for some set VHF software to update position automatically from NMEA input (rather than manual input)
may have missed a step but I am sure someone will point it out
