Low power [less than 350watt] vacuum cleaner
Poignard
23 Jul 2005
South London
No electrical power on my pontoon but I have access to a 350 watt portable generator. Does anyone know of a mains powered vacuum cleaner that will run off this generator? I need it to vacuum up the debris from carpentry jobs from places that can't be reached with a brush.
I have tried these 12volt things and they totally feeble. I also looked at the Dyson DC12 re-chargeable, but with a 5 minute operating time, before neeeding recharging for several hours, that is a joke.
The Waeco 12v one is also a bit feeble, though it will easily run for 15 mins on one charge.
If you are not in a marina when you need to vacuum, why not set up a plain suction fan to extract the sawdust and stuff, and blow it directly outside the boat into a bin ?
Sorry most modern vacuum cleaners are in the 1000 to 1200 watt range. That is the only way to get real suction power. I suggest you find a berth even temporary with power outlet or borrow a bigger generator.
good luck olewill
Damp j cloth tied on a stick works well in bilge recesses.Dunk and repeat useage until ...
Have a look at the smaller full power Dirt Devil range of vacuum cleaners.
I want something to get the dust out of really small crevices that you wouldn't get a stick and j-cloth into.
Had a look at the Dirt Devil spec but it draws 3 Amps and:- 3 amps X 240 volts = 720 Watts /forums/images/graemlins/frown.gif
Looks like a bigger generator needed [more expense and weight] or move to a commercial marina [much more expense!]
I remember once seeing a picture of an old advert for a hand operated vacuum cleaner being operated by two Victorian chambermaids, like a set of blacksmith's bellows in reverse. Something like that might do [especially if the Victorian chambermaids were included See here! ].
Your home (cylinder) vacuum might run on a cheap inverter...try a 1500W cheapo. I would NEVER recommend a cheap (non-sine) for anything electronic and certainly not for long-term draw from a battery but for your application it might do the job if you keep your engine running while you do it. BTW - we are talking about 125A from your batteries /forums/images/graemlins/shocked.gif so you need good leads a la alternator cable, and don't run it for more than, say, five mins on and ten mins off and you should be OK.
Be careful with a non sine wave inverter for a vac, the ussue with non sine or modified sinewave is when one tries to run an inductive load - ie, a motor in a vac. If you do use one watch out for overheating of the motor.
I can't check the wattage because it's on the boat, but we use a Dirt Devil DD150 on a 150w max/300w peak invertor, so I'm pretty sure it can't be a 750w motor.. Sometimes use it with the cheapo genny too. Great little cleaner by the way.
Makro---rechargeable "wet & dry" vacuum, you can even use it to suck the last bit of water out of the bilges. Does a good job on the dry bits as well. All for a princely £9.99 plus the VAT. No connection etc, etc--just a happy user.
If you can't suck it out, how about blowing it out with compressed air?
Electrolux vacuum cleaners are of the brush type motor ie not inductive so should run OK on a bad inverter. I think most vacuums are the brush type motors to get the higher speed for the 2 stage centrifugal compressor. olewill
