MagicalArmchair
I waved Triola (that I sold to her new owner at the end of last year) off for her 1,000 mile exciting adventure back to her new home port in Poland earlier this week.
The new owner arrived in Amsterdam this morning, and to my horror, calls me and informs me (in a very charming, calm and pleasant way) that the Flexofold prop, that I fitted five years ago (and wrote an article about fitting in PBO 599), fell off as he came to dock!!! The content of the article, and the process I went through to fit it, is here: Fit a Flexofold propeller - Triola - Albin Ballad #50 - Flexofolds instructions are here: http://www.flexofold.com/upload_dir/docs/2-blade-US-shaft-2_0_2013.pdf
I stayed in very close contact with Flexofold during the whole process as I was writing it up, any uncertainty I contacted them and clarified any points.
They know where the prop is thankfully, so are sending down divers to get it, however, this prop would only have fallen off if I would have ballsed something up when I fitted it. What is incorrect in the above? One point in my article leaps out at me:
Going over my emails with Flexofold, I find some other baffling exchanges:
Me (a bitter irony reading it back):
Flexofold:
Questions:
My concern at this point was two fold, the prop nut locking grub screw, which I assumed would locate onto a flat face of the prop nut was locating onto part of the circular body of the nut. Additionally, there was a bit of unused thread on the nut. I contacted the long suffering (but still very helpful) Flexofold and they advised this was perfectly normal and the grub screw was supposed to locate onto the body of the nut, not one of the faces.
Hello, The hub arrived today, many thanks. I note the prop nut locking grub screw has no thread lock on it – is it worth putting any on? I wouldn’t want my new prop falling off J Thanks
Flexofold:
No, you don´t need Loctite on the nut. If you just follow the mounting instruction, you can be sure that the propeller will be safe on the shaft. Best regards,
Questions:
- Where did I balls the above up? Following the manufacturer's instructions is clearly not good enough. Note to self, trust yourself more, apply more threadlock (although, note in the documentation from Flexofold, it says "There is an underwater proof thread locker pre-applied on all screws in the installation)".
- When the prop came off, do we think it would have sheered the key and just unwound itself? viz: The diver will be looking for one prop, not many parts of prop?
- What will the owner need to get the prop back on, presuming the diver finds it? A new key for the shaft?
- How does the new owner prevent this happening again when refitting?
