odrisc2
when adding or replacing anodes on a shaft. so it wont come loose what do people generally do or add? Loctite?
Loctite 243 .
Buy don’t be tempted to nip up later after setting as you will break the grip .
Don,t ask how I found out![]()
what u mean?
you put on loctite then came back to tighten bolts and it had set?
so you tap the 2 halves together with hamner?
just add loctite to threads at end?
Received wisdom seems to be to hammer the two halves together on the shaft but it's important either to hit both halves exactly simultaneously with two equal size hammers, or use one hammer and press a block of concrete or metal, or a large block of heavy wood, firmly on the non-hammer side, to avoid damage to the shaft and bearings. I'm not convinced about this; certainly it enables the bolts to be screwed in some more but with or without hammering the torque/tightness will be the same and consequently the 'grip' of the anode on the shaft will be the same. Loctite or equivalent is a good thing to use in either case. I also placed S/S jubilee clips above and below the anode so that if it did come loose it wouldn't interfere with the cutless bearing in the P bracket and the water flow to it, or in odd circumstances work its way up the shaft and do the same to the gland.
Good quality anodes have a steel inner so just the zinc erodes. Whacking them ensures the liner is firmly on the shaft so you can do the fastenings up solidly.
Works for me.so tap at same time with the 2 hammers and loctite on thread..
