Tim Good
I was anti fouling today and found the prop shaft bracket was loose and wiggles both forwards and backwards and side to side. Seems like it is a separate piece and fixed by bolts maybe and then you can see the glass fibre mould over the top of it on the inside under the aft cabin bunk.
My question is how urgent is this! It's only a 1GM10 Yanmar. Should I be getting this sorted like ASAP or will it be ok until the next time I lift the boat?
In another note, what is the solution?
