looking for two round Air Vents 100mm Spigot with tamper
vas
21 Jun 2011
Volos-Athens
title says it all really!
Now that I realised my air con works and its 24kbtu, I decided to route pipes to the bow cabin and get another outlet on the salon.
To do so, I need some air vents, black, plastic, round, with a grille that turns so that air is directed to your needs and there's a tamper as well so you can close or reduce flow if you wish using a small rotary knob in the middle of the vent. They have to be for 100mm dia pipe.
I've got two of them already onboard but I CANNOT find any place that sells them!
anyone can help?
cheers
V.
thanks Bouba but this is 70mm pipe, 100mm overal dia of the assembly.
If I go for 70, I'll need 4 of them (two on each cabin) as too small to get smooth air out.
cheers
V.
thank you all!
Vas, these used to be standard fit on many cars. It may pay you to have a snoop around a car breaker (dismantler).
P. yes, but they are all 3inch or 75mm dia pipework at best, not enough for the bow cabin!
That's the right size but since it's going to fitted on a ceiling panel, grille should be fixed at an angle and able to rotate in plan, this is more of an extraction assembly piece with the flow of air "lifting" the grille when needed...
Ah! that's exactly what I have in the other cabins! not buying two grilles from the US though if I can help it!
Just bought exactly tus spec from Brian Wards in Brundall Norfolk for ky ebby outlet at 100mm with pipe spiggot.
Not cheap but available!
thanks, searched their online shop, couldn't find them, wonder if it was a one off, or if they do still stock them.
cheers
V.
Hi it was a special order ringthem and talk to Tanya or Nick and they will order them for you. Tell them it the same as the one they just bid for me (steve biggs)
Be warned they are £80! But was just what I wanted and worked great with Aluminium spigot tube about 5 inch long
Send me a pm with your email and will send you what it looks like installed from the front as it rotates and closes but not as you detailed but other than that its your exact spec
Steve,
just realised 80quid for a fcking air vent, sorry wont do it!
That's going to be 200quid for two shipped to Greece...
I'm better off buying from the states :(
cheers
V.
Steve,
cheers
V.
Just out of interest, did you see how much the shipping was from the states? They do ship to Greece.
no, but I've bought quite a few things from the US, it shouldn't be more than 40usd.
Basically, since there's no easy EU online option, I'll have a go at a couple more chandleries in Athens when I'm next there, hoping to find them, if not, I'll order from the US.
It's not something I can use right now as I got to find way to route the pipes to the bow cabin, and heat waves are over down here, so not in a hurry :D
cheers
V.
