I got called to one which had gone totally inverted. We got it back upright, but water was coming in through the top of the centreboard case as fast as we were pumping it out. We had to beach it in the end.The early ones have a known issue of flooding through the top of the plate case which is low & the outboard well is another point where water can come in when swamped,
The Dabber appears to be a good stable boat but when swamped water level is effectively at deck (seating level) probably why they were fitted with large bilge pumps!
Early dabbers had the centreboard arm flush with the top of the plate case so there was a slot about 2 1/2" deep at the front of the case, later ones had this filled in with the arm higher, this in an effort to lessen water ingress.
My thoughts entirely. This type of boat is often talked about as a large dinghy. It should behave like a dinghy and be as safe as a dinghy and capable of sustaining a capsize and self righting without sinking.Any day boat / dinghy / un-ballasted boat is liable to capsize and should be a known & likely risk. It’s then swamped water level being above that of a keel box / source of water ingression preventing a self rescue should therefore be an unacceptable design feature.
Rubber flaps would do, not much can be done about the O/B well though.Early dabbers had the centreboard arm flush with the top of the plate case so there was a slot about 2 1/2" deep at the front of the case, later ones had this filled in with the arm higher, this in an effort to lessen water ingress.
I am surprised this has not been talked about before, a lot of people hold Drascombes in high regard so are we to conclude capsizes are rare but when they do happen not self recoverable?
I would say the 'design' is one thing and the state of an individual boat is quite a different thing.I would [evidently naively] have thought that sort of downright dangerous design wouldn’t have been allowed exist into production with going through RCD.
Designed long before the RCD was devised. It was first built in 1971! Even now it is is Cat D (inland waterways only!) which is pretty undemanding, although there will be buoyancy requirements in the standards. I would imagine there were changes required in 1997 to meet the RCD, but probably nothing dramatic.I would [evidently naively] have thought that sort of downright dangerous design wouldn’t have been allowed exist into production with going through RCD.
A lugger if I remember rightly? One person - unless there are multiple cases. Lots of Drascombe's around and usually sailed without safety cover so not that surprising.Lucky rescue. I may be mistaken, and too poor reception to research fully, but hasn't there been at least one (double?) fatality after a Drascombe (Coaster?) capsized?
I don't think the RCD actually used the words inland waterways anywhere - it refers to the areas by wave height and wind conditions; the previous version referred to Cat D as "Sheltered Waters" but that label has been removed. It now says F4 winds and significant wave heights of 0.3m, with occasional 0.5m waves.Designed long before the RCD was devised. It was first built in 1971! Even now it is is Cat D (inland waterways only!)
Hard to tell in the photo but I don't think the significant wave height is >30cm in the picture so probably "in spec".which is pretty undemanding, although there will be buoyancy requirements in the standards. I would imagine there were changes required in 1997 to meet the RCD, but probably nothing dramatic.
Clearly this boat was being used outside the areas it was designed for. Good that we don't have laws to prevent people from doing this, unlike some countries.
