Jomo
Having bought a new (to us) boat last year, and spent the winter trying to fix as much as I could, I finally turned to the engine. The original is a Volvo 2003T. The turbo had seized at survey, and the heat exchanger is spraying water from the joint below the turbo (judging by the corrosion). However, the engine was started (with some difficulty) a couple of weeks ago, so it does run. If everything else is good (yep, I know, big if), I could be looking at £700.00 for turbo repair, and up to £2500.00 for a replacement heat exchanger, plus fitting, say £3500.00 all in.
On looking around, a Lombardini 1404 should fit the slot if I went for a replacement. I can't currently find anything else that'll fit without a fair amount of sawing, bashing, drilling, etc, etc. I can get a new Lombardini delivered for about £5600.00, and it shouldn't need much in the way of jemmying into position. However, my 'professional mentor sucked large amount of air through his teeth when I detailed my plan, indicating he wouldn't have anything to do with them.
So, can anyone give any feedback on the Lombardini engines. I realise they are lighter and cheaper, but will they handle the environment? Or is there anything out there that might fit in a slot previously holding a Volvo2003T?
Ian
Ian
