logging a passage plan
Petercatterall
2 Jul 2002
Lancashire
Just read the previous humerous thread on this subject but when is it sensible/resonable to log your plan with the CG?
A recent trip from the IOM seemed very straightforward but when crew got sick and weather turned worse than forcast I began to feel that it would have been a bit of a comfort to have logged our plan. What is the correct form on this please?
BrendanS
11 Jun 2002
Tesla in Space
Whenever you feel it warrants it really.
I travel a hundred miles or more on some trips, but just make sure I have a shore based contact to alert the coastguard with details if I don't log in on time. I do have a CG66 logged with coastguard, but don't feel it necessary to call them for most trips, as they won't do anything unless a shore based contact calls them to report you missing anyway - so why bother contacting them with trip details, if it depends on shore contact initiating search anyway?
starboard
22 Dec 2003
N5533 W00441
Can't speak for down on the Solent but up here on the Clyde the CG only too happy to take your TR. I sail single handed most of the time and even for a short hop of 15 miles across to Arran from Troon I will generally call the CG unless of course they are busy casualty working. This will not only give you a chance to confirm that your radio is working ok but will give the coastguard a heads up on your intentions, indeed if subsequently they may be able to utilise you if something should happen to any other vessel on your known intended track. I found in my Lifeboat career the VHF radio is without doubt the best safety aid you will ever own......and a little bit of practise in its use will give you more confidence to use it should it all turn pear shaped!!!
Paul
chubby
28 Mar 2005
hampshire, uk
I realise the CG don`t go looking for you unless the shore contact reports you overdue ( when they did a yacht safety info broadcast invaribly found the overdue yachtie in a pub in Cowes having given up on Cherbourg) but find it good RT practice and a more functional check of both set and operator to pass a TR for trips out of sight of land, i.e. cross chanel or cross Lyme bay for a South coast boat. Was ammused to hear the skipper of a 42 ft motor yacht spend a long time trying to send a TR on ch16 for a trip from Swanwick to Gosport! a bit OTT: a slight hint of sarcasm in the Cg reply: "have a save trip captain"!
