Mudisox
My cayman anchor winch was loosened when last used and so I dismounted it, finding considerable corrosion of the Aluminium body. It is exposed both from the sea above deck and the chain locker with wet chain only approx 100mm below.
However It has lasted 20+ years and the previous owner must have also had the same problem using GRP/epoxy to build it up where it had corroded, but was then mounted on a plastic board on top of an oak board, which was then sealant to solid GRP deck and through s/s bolts backed up below.
I have cleaned off the old "epoxy glue"and the corroded salts will be pressure washed back to clean alloy.
Do I repeat the same process, building up the 'wasted away' aluminium with " epoxy paste" [ It lasted for 20+ after all] ,] or bite on the bullet and get a new part with the associated delay in getting it from Italy, the hassle of stripping the winch insides and the remounting?
Was the Oak board a problem?
Will Duralac sufficiently insulate the cleaned Aluminium prior to epoxy build up?
Will attaching an anode to the underside backing help.?{ Bolts are s/s.]
Picture is too large but can send by PM.
