Cardinal
Ean_p, thanks for posting the link. I was just going to ask for that since I realised that I need not sweat over the bearing removal as it is the casing which I am replacing and so will just slip in a new bearing. From what you have written, that sounds like a task not without risk.
The whole reason for this is that the mounting studs pulled out of the casing due to corrosion. The replacement will be mounted a little differently on a chopping board and will be dismounted at the end of the season. Lots of Duralac will be used on the studs.
