Krusty
We have made countless transits of Loch Ness in forty years, but none quite like this one on 25th October.
We had already split the working Mainsail in the Hebrides, sent it for repair and bent on a smaller leech-cut 'heavy-weather' Main. It is twenty years old but still bomb-proof. Double-reefed, it is about the same area as my storm trysail.
Why not a storm jib? Because at the loch end, the safe exit channel is only a third of a cable wide into a blind bend, and quite large ships can suddenly appear, making it virtually a dead-end. Whenever we run towards a lee shore I prefer sails that I know will drive the boat to windward if necessary.
The Inshore Waters forecasts relevant to both ends of the canal were essentially the same (from memory): Westerly F8, veering and increasing F9 or F10.
But Loch Ness is a sheltered inland waterway and its weather is always less than at sea, isn't it?
As far as Urquhart Castle that was right enough, but then came the wind out of the Glen!
Well, here's the result.
Pionier 10 (van de Stadt) LWL 7.35m; designed ''Hull speed'' 6.9kn.
Fort Augustus pontoon to anchorage in Loch Dochfour: -
Charted distance 20.0 nM. Passage time 2hrs 25 min. Av. speed 8.2kn.
Sustained periods of surfing at 9 to 11kn, peaking over 12kn. Max. seen 12.4kn.
We took a few video-clips. At first using the camera was no problem. Beyond Urquhart it was far from easy, but I managed a couple of clips. Then, when I believed it was at the top, it suddenly ratcheted up another full F Beaufort and we began surfing up to 12 knots, with solid bow-waves almost reaching the upper guardrail. Exhilarating stuff!
At that stage we both had to give total attention to the boat to ensure controlled gybing to make certain of the best approach to the exit. No room for errors!
So the camera missed the best parts, and I very much regret not having a 'ready-use' fixed mounting.
Anyway, for some the short video may be of interest. For us, it was tremendous fun. Exhilarating, even!
The lock-keepers informed us that no other vessel made a transit of the loch that day.
Click on:-
http://s215.photobucket.com/albums/cc310...nupLochNess.flv
Click on:-
