Location of Navtex aerial?
Leif-J
23 Dec 2011
Denmark
I am fitting a Furuno NX-300 and wonder, where best to put the mushroom shaped aerial. It is likely to fish a line almost no matter where I put it, and I also need to have it out of reach of my radar beam. So I wonder if it need be over deck, or I might fit it underneath somewhere? Or will this reduce the sensivity?
Another option would be to put it up somewhere in my back stay out of reach - sort of anyway.
Forgive me if this subect has been discussed earlier - could not find it anywhere when searching.
Brgds
Leif
aluijten
26 Oct 2004
Dordrecht, The Netherlands
Actually, the antenna can be put even inside of a GRP yacht. You will have a little less reception there, but not much. The receiver is quite sensitive.
I had mine (same model) behind the switch panel that also has the display unit installed and I still received quite a lot of messages. It's now on a custom build pole together with a few other aerials (AIS/GPS/Radar).
Although I would not put it directly in the beam of your radar, in close proximity shouldn't be too much of a problem as the frequencies for these devices are quite different.
Leif-J
23 Dec 2011
Denmark
Think I will start trying the reception with the aerial inside then. Can always start drilling (more) holes in my poor boat later.
Btw aluijten, like your avatar - very fond of cats, me and SWMO.
aluijten
26 Oct 2004
Thank you very much. It used to be one of our beloved crew mates. It died prematurely (cancer). During it's lifetime it was the Burmese equivalent of Arnold Schwarzenegger or Jean Claude van Damme. All muscles, hardly brains :) But he loved being on the boat.
Billjratt
9 Sep 2004
Firth of Clyde
Furuno is a very good unit and will "hear" better than some others. The most important thing is to keep the aerial away from other electrical noise (like flourescent lights etc.), then it will be able to recieve the signals without interruption.
maby
12 Jun 2009
Navtex operates on a pretty low frequency - the "correct" antenna would be several hundred metres long and mounted a good hundred metres or more up in the air - obviously not practical on a boat. All the Navtex antennae we use on pleasure boats are very heavily loaded, amplified antennae and, as such, are pretty unaffected by position - they all perform very badly in absolute terms. As others have said, the more critical consideration is to keep it as far as possible from sources of interference - which include fluorescent lighting, motorised equipment and electronics.
RobinBirch
15 Mar 2007
Nottingham
My Navtex antenna sits out of harms way in the rear cabin. Reception/signal seem fine. It used to sit on the guard, kept on being knocked and finally the mounting bracket gave up.
Twister_Ken
31 May 2001
'ang on a mo, I'll just take some bearings
I put a NASA Navtex aerial below decks (up against the coachroof side) on the old boat. NASA kit is pretty low end, but it worked well enough there. I've been looking at Navtex for the new boat, and quite fancy the ICS which has been redesigned in the last year to do away with a tiny and low profile aerial with some integrated electrickery, to a two box solution with a plain vanilla but large aerial. One reason I'm hesitating is my reluctance to put a big aerial somewhere vulnerable. I'm wondering whether I can fit it in some dead space in the aft cabin.
Leif-J
23 Dec 2011
Denmark
Thanks for good advice everyone. I shall try my luck at placing it indoors first - and try to avoid electronics. Wonder where that would be, it seems to be everywhere nowadays.:)
Ex-SolentBoy
25 Nov 2006
Or you could get one of these. I keep mine in the chart table. No drilling and you can take it home. Turn it on before you leave have the latest broadcasts immediately.
http://www.mesltd.co.uk/moerer-wib2b-black-navtex-with-barograph-function-p-11173.html
