bremar
Active Member
I have 2 solar panels feeding through a controller to a 100 a/h battery. There is the standard'ish large red manual cut off switch that cuts off the battery from everything. I have no engine charging and only this one battery for navigation lights,navigation equipment,interior lighting and power generally.
When I leave the boat on its swinging mooring I always have a debate with myself as to whether to switch it off or not because the solar panels will not be able to charge the battery if I do.
I have read through nearly all the posts on solar panels in this forum but none seem to directly address the best way of tackling the location in the wiring of a battery cut off switch.
Subject to any observations you chaps may have I think I want to bypass the battery cut of switch so that the solar panels feed directly to the battery, that way charging continues while I'm away and I can switch of the other electrics. BUT:
1. What safety precautions should I take? I don't want to worry about the wiring shorting and causing a fire etc. And
2. I appreciate that there is a "load" take of point on the solar panel controller , which would still be available if the solar panels were connected directly to the battery and I used the battery cut off switch to disconnect the rest of the electrics but I'm not sure if there's a need for me to use this to power anything if I'm away from the boat?
Than you in advance
Bremar.
Than you in advance
Bremar.
